Raster Attribute Table related issue in ArcGIS Pro 3.5.5
631
01-09-2026 01:50 AM
DineshRai
In ArcGIS Pro 3.5.5, when generating a Raster Attribute Table (RAT) for Land Use/Land Cover (LULC) rasters, the existing colormap configuration is reset. Ideally, building a RAT should not alter or remove the colormap, as the colors represent class information critical for LULC analysis and visualization.
Version
Behavior
Remarks
ArcGIS Pro 3.3
Ports easy to click; functions respect connection; no resets
It is working fine for Raster Attribute Table (Output) connected to defined Colormap.
ArcGIS Pro 3.5.5
Auto-snaps to raster, port hitboxes smaller, node resets, Attribute Table chaining unreliable
Not able to Prepare Raster Attribute Table (Output) connected to defined Colormap.
Robert_LeClair
Esri Esteemed Contributor
@DineshRai - I see that you were working with Esri Support Services on this question and it was determined to be BUG-000181746 - "In ArcGIS Pro 3.5.5, the isPublic variable in the Colormap function becomes uneditable after connecting with a mosaic dataset through the attribute table in the Function Editor."  It currently shows fixed at ArcGIS Pro 3.6.
DineshRai
I am currently using ArcGIS Pro 3.5.5 along with ArcGIS Enterprise 11.5. Therefore, I request that the issue be resolved within the ArcGIS Pro 3.5.5 environment, without requiring any change or upgrade to the ArcGIS Pro version.
Robert_LeClair
I understand your situation @DineshRai but working in Esri Training Services I have zero control over where BUG fixes are implemented.  You can call Esri Support Services to see if there is any plan for backwards compatibility to 3.5.5 with this fix.
