Ran the Detection software to check computer for minimum requirements meet minimum ram 512 reqired I have 2.0
1621
07-01-2022 08:30 AM
RussellBrownell1
I downloaded and ran the ArcGIS Pro detection software to check computer for minimum requirements. Dedicated Video RAM says minimum ram 512MB is required. I have 2.0GB.
I select the "Recommended" tab and the dedicated Video RAM is 4.0GB is required and I have 2.0GB whats up here?
DanPatterson
MVP Esteemed Contributor
minimum is the minimum needed to run Pro
"recommended" is what the user should have for Pro interactions that may be graphics intensive or require gpu.
you are between minimum and recommended, ergo OK 😉
... sort of retired...
DanPatterson
RussellBrownell1
Thank you dan,
Russ
