"Add Error Layers" disabled
6363
11-23-2022 10:18 PM
IhabHassan
Hi All,
I have a feature class that has 1 of the data-reviewer "Ready to use rules", the feature class resides in an Enterprise geodatabase, branch versioned, database connection is using data owner account. The validation feature classes are all created and also branch version enabled.
I am trying to add the error layers to Pro map, but the option is disabled. Any idea what am I missing?
Regards
Ihab
IhabHassan
thanks heaps @SamPienaar , it is now working
the steps that Sam pointed out to get the error inspector working against feature service:
* ensure you are accessing the database through branch version connection
* ensure your datasets are version enabled
* manually add the datasets and the error layers into Pro map
* publish feature service and ensure "Validation" capability is enabled
* from Pro catalog, browse to Portal, then to the published feature service, and add only the sub layer that has attribute rules
* from the Pro map contents panel, right click the sub layer, choose "Add Error Layers"
now you can validate the rules against feature service from the "Error Inspector" panel..
Regards
Ihab
IhabHassan
Regards
Ihab
JordanCampbellUAF
how do I do the first two points?
AyanPalit
@JordanCampbellUAF This is an old thread with a marked solution. Best to post your new question as your use case / ArcGIS Pro version may be different.
The following links may help:
Share datasets with attribute rules
Implement automated quality control
Ayan Palit | Principal Consultant Esri
HNTZK46
Hi Ihab,
I am having a similar problem now. I created validation rule using Arcade script for datasets in Enterprise GDB, and then I published. But when I add the published feature service to ArcGIS Pro, the "Add Error Layers" option is greyed out. I tried the steps that you mentioned as solution but it still did not work for my case.
Did you use only "Read to use rules" function when you created validation rules?
Did you add all the four error layers (e.g. ValidationObjectErrors, etc.) into Pro map when you publish the service?
Thanks for your help.
DiegoLlamasOlivares
Hello,
did you solved this issue?
Thanks.
DLL
