"A column was specified that does not exist"; File GDB point feature class
23620
9
04-20-2023 10:07 AM
MichaelMarlatt1
Hello there,
I'm using Pro ver 3.0 currently.  I am having trouble with a point feature class that's not allowing its attribute table to be viewed.  When I click on points I can see what I expect to see in the Pop-up window, but when I try to open the attribute table, or look at it in a Catalog window, I get the message "Failed to load data. A column was specified that does not exist."  Specified by what?  How can I find out what's supposedly missing so I can do something about it?
The feature class in question was created in FME Workbench (I have posted in their forums too) from an excel file.  I have found numerous posts that involve using cursors in Python but I am not sure that helps in this case.  Has anyone figured out how to troubleshoot this problem?
Mike
DavidPike
MVP Notable Contributor
'GROUP' sticks out to me
DavidPike
Do you have OBJECTIDs?  Might be struggling to query the data without a primary key.  Any potentially reserved SQL or ArcGIS names for the Excel columns?  Did the original data participate in a join and didn't come across?
MichaelMarlatt1
Yes the OBJECTID column is created by the FME software.  No reserved words that I recognize in the column names and the source data is not in a join.
RaymondHuang_Sg
Could you share a screenshot of the fieldnames for this feature class?
Cheers,
Raymond
MichaelMarlatt1
Attached is what I am able to see in Pro's pop-up window when I click on one of the points in the feature class.
DavidPike
MichaelMarlatt1
That did it!  I changed 'Group' to something else and the problem went away.  Thank you @DavidPike !
What is it about 'Group' that was causing the problem?
DavidPike
Found this for posterity https://support.esri.com/en-us/knowledge-base/faq-what-are-the-reserved-words-for-esris-file-geodata...
When you open the attribute table it's running a SQL query against the database (FGDB) (I think!).  GROUP is a reserved SQL keyword and probably causing a syntax error which there was no explicit error handling for (considering that FME is an unknown variable).  Just my musings however.
SadieGoodrum
I have had this problem before, when you convert the data it creates Multipart input features. This will cause an issue opening the attribute table. you can run a Geoprocessing tool. You use the Muiltpart to Singlepart Geoprocessing tool, this will create a feature class containing Singlepart features. You should be able to open your attribute table after that no problem.
GISHCR
Had the same issue, I renamed the txt file and it worked (originally was xy 0.5 Well Search)
Guess it doesn't like decimals in titles
