QOL improvements for construct polygons modify tool
740
04-23-2025 11:09 AM
jbcypreste
I'm always using Construct polygons tool on modify since it's quick and more seamless than having to do append or the daunting copy-paste process. But as interesting as it is, it still lacks functionality?
For example, why does it explode the source feature? If I'm copying a multipart feature from one layer to another, I want it to remain a multipart, not be exploded in the process.
And also, why does it fill the gaps on the source features by creating a new feature? Same thing, why would I want it to fill the gaps that aren't part of anything in the first place?
Perhaps I'm misusing the construct polygons as a copy-paste tool? Because it would be really cool to have one like that, even though I feel like construct polygons gets 90% of the job done.
Scott_Harris
Hi @jbcypreste
The Construct Polygons tool creates a polygon feature for each closed boundary formed by selected lines and/or polygon features (both can be inputs). A common use case: you have a closed loop of lines that you want to convert into a polygon. I wouldn't recommend Construct Polygons as an alternative to Paste Special.
jbcypreste
This sounds like a very niche use for construct polygons, I think it would benefit more if the copy/paste options were integrated into it. Paste special is okay but there are too many steps (specially when attributes/fields aren't relevant) and slow when dealing with large geometries.
