Python Toolbox: parameter data type to access a field(s) in a table
1154
6
04-29-2026 01:31 PM
JaredPilbeam2
I'm attempting to create a python toolbox script that geocodes a CSV. It will be my version of the Geocode Addresses tool. What do I need to do to get the Field parameter to accept the 'ADDRESS' field of my CSV? Right now, the 3rd param accepts a Field datatype. I didn't see a good option in parameter controls either. If i run this tool as is I receive errors. Two of the errors mention needing an output parameter, which I'll get to. I'm assuming Error 000800 is referring to the Field parameter, but beyond that I don't really know. Maybe it's in the script itself.
class GeocodeFile:
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Geocode File"
        self.description = "Geocodes a local file and saves it back to the same directory."
        self.params = arcpy.GetParameterInfo()
    def getParameterInfo(self):
        """Define the tool parameters."""
        # 1st param
        param0 = arcpy.Parameter(
            displayName="Your CSV",
            name="your_csv",
            datatype="DEFile",
            parameterType='Required',
            direction='Input'
        # 2nd param
        param1 = arcpy.Parameter(
            displayName="Geocoder",
            name='geocoder',
            datatype="DEAddressLocator",
            direction='Input'
        # 3rd param
        param2 = arcpy.Parameter(
            displayName="Field",
            name='fields',
            datatype="Field",
            direction='Input',
        # param2.controlCLSID = '{172840BF-D385-4F83-80E8-2AC3B79EB0E0}'
        # param2.value="ADDRESS"
        params = [param0,param1,param2]
        return params
    def isLicensed(self):
        """Set whether the tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter. This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        import arcpy
        arcpy.geocoding.GeocodeFile(
            in_table=parameters[0].valueAsText,
            locator=parameters[1].valueAsText,
            address_fields=parameters[2].valueAsText,
            output_type=parameters[0].valueAsText,
            # output_location=r"C:\Users\test",
            # output_name="geocodedfile",
            # country=None,
            # location_type="ROUTING_LOCATION",
            # category=None,
            # output_fields="ALL"
        return
    def postExecute(self, parameters):
        """This method takes place after outputs are processed and
        added to the display."""
        return
AlfredBaldenweck
MVP Frequent Contributor
I think it may be a problem with your field parameter. The geocode tool takes a FieldInfo Parameter (idk how those work) and you're feeding it either a Field (original post) or a value table.
Are you able to get the tool to run normally, outside of the toolbox?
DanPatterson
MVP Esteemed Contributor
Python Toolbox: parameter data type to access a fi... - Esri Community
The field names have a dependency  on the input file and on a quick read the setup might be the same as in the code examples.  Under Value table parameters there is an example which sets this for the parameter list (eg param1.parameterDependencies = [param0.name] )
Custom toolboxes make this visually easier to setup if you want to experiment with that first
... sort of retired...
JaredPilbeam2
Thanks @DanPatterson ,
I'm using a Python Toolbox because the end product not mentioned here requires it. Value table got me a step closer it appears. Now I'm able to get param1 Address Field to populate with fields from the input CSV. I also gave it an out file param. But, all the params still don't seem to be functioning as a whole.
        # 1st param
            name="your_csv",
            datatype="DEFile",
            direction='Input'
            displayName='Address Field',
            name='ADDRESS',
            datatype='GPValueTable',
            direction='Input'
        param1.columns = [['Field', 'Field']]
        # 2nd param
            name='geocoder',
            direction='Input'
        # 3rd param
        param3 = arcpy.Parameter(
            displayName="Out File",
            name='out_file',
            datatype="DEFile",
            direction='Output',
        params = [param0,param1,param2,param3]
        return params
        import arcpy
            locator=parameters[2].valueAsText,
            address_fields=parameters[1].valueAsText,
            # output_location=r"C:\Users\me\test",
            # country=None,
            # category=None,
AlfredBaldenweck
So, looking at those error messages, it looks like you have the following problems:
  1. Is your input CSV actually a CSV? GeocodeFile() doesn't think it is, and I can't see the file extension on your screenshots. You might want to add a filter to that parameter to ensure you get the right file type in there.
  2. The issue for output location and output name is that you're not providing a destination for the output file to GeocodeFile(). For example, in both code blocks you've attached, those parameters are commented out. They look like they're required.
    1. Using the output parameter the way you're doing now is a good idea, but you're going to have to split the location and the name before feeding them to GeocodeFile()
  3. You're also going to have problems using the first parameter for the output format, since that parameter takes specific values. I plugged in "CSV" below.
        import arcpy
        import os
        outfile = parameters[3].valueAsText
        outloc = os.path.dirname(outfile)
        outname = os.path.basename(outfile)
            output_type= "CSV",
            output_location= outloc,
            output_name= outname,
            # country=None,
            # category=None,
JaredPilbeam2
Thanks @AlfredBaldenweck ,
1.) Yes, I have only been testing CSVs. Added a filter anyway.
2.) I should've had this filled out completely to begin with. It's a lot clearer now.
3) Added a filter here too. Seems to be fine now.
All in all those were good fixes. It's narrowed down to two errors tied to the GeocodeFile() function which have pretty unhelpful pages. Error 003346 and Error 002617
arcgisscripting.ExecuteError: ERROR 003346: Geocode File failed.
ERROR 002617: Batch Geocoding stopped with status esriJobFailed.
Failed to execute (GeocodeFile).
Things I've looked into regarding the geocoding errors:
1. Our locators are hosted on Enterprise Portal v. 11.3 which allows batch geocoding up to 1000 rows.
2. I've tested with different CSVs, different addresses and different field value formats.
3. The locator coordinate system is set for NAD_83.
4. I've been trying different locators and the tool has not ran with any of them while every time it has produced at least one of the two errors above. Error 002618 was also produced once too.
AlfredBaldenweck
JaredPilbeam2
Your suspicion was correct. I simply removed the field parameter and hardcoded what the Geocode File tool accepts and the tool ran without any error.
        import arcpy
        import os
        outfile = parameters[2].valueAsText
            #Geocode File tool Address Field Mapping parameter
            address_fields="'Single Line Input' ADDRESS VISIBLE NONE",
            output_type="CSV",
            output_location=outloc,
            output_name=outname,
