Python script to calculate NDVI anomalies.
12383
33
06-07-2018 12:11 PM
LuizVianna
Why the last line of this code is not working? It is the line of "Minus_3d" calculation?
This is a python script to calculate NDVI anomalies.
Thanks.
# Import arcpy module
import arcpy
from arcpy import env
from arcpy.sa import *
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
#Define workspaces
arcpy.env.workspace="D:\\Modis250\\NDVI_10dias_norm" #Workspace with decendial (ten days period) NDVI
#Filenames standard is "norm_ndvi_yyyy_dec_d.tif" where "yyyy" is the year and "d" is the ten days period: d=1 = january 1-10; d=2 = january 11-20; ...
for n in range (1,37):
d=str(1)
y = str(2004)
NDVINormAll=arcpy.ListRasters("norm_ndvi_*_"+d+".tif", "tif")#List of decendial NDVI for all years to calculate the dcendial mean
NDVINormY=arcpy.ListRasters("norm_ndvi_"+y+"_dec_"+d+".tif", "tif")#List of decendial NDVI rasters for the last year (y)
NDVIMeanOut = "D:\\Modis250\\NDVI_10dias_mean\\"+"mean_dec_"+d+".tif" #Define the decendial NDVI mean output (could be temporary)
NDVIMean = arcpy.gp.CellStatistics_sa(NDVINormAll, NDVIMeanOut,"MEAN", "NODATA")#Calculate the decendial NDVI mean (could be temporary)
NDVIAnomOut = "D:\\Modis250\\NDVI_10dias_anom\\"+"anom_"+y+"_dec_"+d+".tif" #Define the last year decendial NDVI anomaly output
NDVIAnom=arcpy.gp.Minus_3d(NDVINormY, NDVIMean, NDVIAnomOut) #Calculate the last year decendial NDVI anomaly and record the output tifs
print ("Decade "+d+" of "+y+" ok")
XanderBakker
Esri Esteemed Contributor
Maybe something like the untested code below could work:
def main():
    import arcpy
    import os
    # Check out SA license
    # settings
    ws_norm = r'D:\Modis250\NDVI_10dias_norm'
    ws_mean = r'D:\Modis250\NDVI_10dias_mean'
    ws_anom = r'D:\Modis250\NDVI_10dias_anom'
    # create a list of all raster in norm folder
    arcpy.env.workspace = ws_norm
    lst_ndvi_ras = arcpy.ListRasters()
    # get list of years
    decades = GetListOfDecades(lst_ndvi_ras)
    # loop through each year
    for decade in decades:
        # Get rasters for given year
        lst_ndvi_decade = GetListOfRasterForGivenDecade(lst_ndvi_ras, decade)
        # calculate mean raster for decade
        mean_ras = arcpy.sa.CellStatistics(lst_ndvi_year, "MEAN", "DATA")
        # store mean ras for decade
        # mean_dec_d_.tif
        out_name_mean = "mean_dec_{}_.tif".format(decade)
        out_name_path_mean =  os.path.join(ws_mean, out_name_mean)
        mean_ras.save(out_name_path_mean)
        # loop through each raster in decade
        for ndvi_ras in lst_ndvi_ras:
            # calculate anom for each raster in decade
            # anom_2002_dec_1.tif = norm_ndvi_2002_dec_1.tif - mean_dec_1_.tif;
            minus_ras = arcpy.sa.Minus(ndvi_ras, out_name_path_mean)
            # store anom raster
            out_name_anom = ndvi_ras.replace("norm_ndvi", "anom")
            out_name_path_anom = os.path.join(ws_anom, out_name_anom)
            minus_ras.save(out_name_path_anom)
    # return SA license
    arcpy.CheckInExtension("spatial")
def GetListOfDecades(lst):
    # norm_ndvi_yyyy_dec_d.tif
    lst1 = list(set([r.split("_")[4] for r in lst]))
    return [r.split('.')[0] for r in lst1]
def GetListOfRasterForGivenDecade(lst, decade):
    lst1 = []
    search = "_{}.tif".format(decade)
    for r in lst:
        if search in r.lower():
            lst1.append(r)
    return lst1
if __name__ == '__main__':
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
LuizVianna
Xander,
Is "lst_ndvi_year" in line 27 correct? Is´nt it "lst_ndvi_decade"?
XanderBakker
Good catch , you're absolutely right (that's why I don't like creating code without data to test on).
Additionally on line 36 it should be lst_ndvi_decade instead of  lst_ndvi_ras
LuizVianna
I corrected the code and executed. The error now is:
File "<string>", line 65, in <module>
File "<string>", line 39, in main
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Functions.py", line 4271, in Minus
in_raster_or_constant2)
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Utils.py", line 53, in swapper
result = wrapper(*args, **kwargs)
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Functions.py", line 4268, in Wrapper
["Minus", in_raster_or_constant1, in_raster_or_constant2])
RuntimeError: ERROR 000732: Input Raster: Dataset norm_ndvi_2002_dec_31.tif does not exist or is not supported
XanderBakker
Did it create anything (for other decades) or is this the first decade it processed? Was the mean raster created correctly? Does the mentioned raster exist and is it valid (does it load into Desktop)?
LuizVianna
It created one tif of mean and crashed. The error is:
I've made the same folder structure and sample files available for a period of 3 years in the GoogleDrive (https://drive.google.com/file/d/1G4baOl1NP7G1rEfBpu9SZr4cxEOd1-Jo/view?usp=sharing).
Best.
XanderBakker
Thanks for sharing the data. I made some changes to the code and that seems to be working:
def main():
    import arcpy
    import os
    # settings
    print "lst_ndvi_ras:", lst_ndvi_ras
    # get list of years
    print "decades:", decades
        print "lst_ndvi_decade:", lst_ndvi_decade
        mean_ras = arcpy.sa.CellStatistics(lst_ndvi_decade, "MEAN", "DATA")
        # mean_dec_d_.tif
        out_name_mean = "mean_dec_{}.tif".format(decade)  ###
        print "out_name_path_mean:", out_name_path_mean
        for ndvi_ras in lst_ndvi_decade:
            print "ndvi_ras:", ndvi_ras
            # store anom raster
            print "out_name_path_anom:", out_name_path_anom
    # return SA license
    lst1 = []
    for r in lst:
            lst1.append(r)
    return lst1
    main()
Here an example "anom" raster (anom_2002_dec_1.tif):
LuizVianna
Same error?
File "<string>", line 71, in <module>
File "<string>", line 44, in main
RuntimeError: ERROR 000732: Input Raster: Dataset norm_ndvi_2002_dec_23.tif does not exist or is not supported
DanPatterson_Retired
Using Xander's code or yours?
If it is yours, it is a filename/path problem .  You might need to provide your code again with formatting so that it has line numbers.
in Xander's it is this line
LuizVianna
My code: I´ve tried line 27 and lines 28-29. Both returned errors.
import arcpy
import os
#Define workspaces
     #d=str(n)
     d='{}'.format(n)
     y = str(2004)
     list_ndvi_ras=arcpy.ListRasters("norm_ndvi_*_"+d+".tif", "tif")#List of decendial NDVI for all years to calculate the dcendial mean
     list_ndvi_year=arcpy.ListRasters("norm_ndvi_"+y+"_dec_"+d+".tif", "tif")#List of decendial NDVI rasters for the last year (y)
     ndvi_year = arcpy.env.workspace+str(list_ndvi_year)
     #NDVIMeanOut = "D:\\Modis250\\NDVI_10dias_mean\\"+"mean_dec_"+d+".tif" #Define the decendial NDVI mean output (could be temporary)
     NDVIMeanOut = ("D:\\Modis250\\NDVI_10dias_anom\\mean_dec_{}.tif".format(d))
     NDVIMean = arcpy.gp.CellStatistics_sa(list_ndvi_ras, NDVIMeanOut,"MEAN", "NODATA")#Calculate the decendial NDVI mean (could be temporary)
     #NDVIAnomOut = "D:\\Modis250\\NDVI_10dias_anom\\"+"anom_"+y+"_dec_"+d+".tif" #Define the last year decendial NDVI anomaly output
     NDVIAnomOut = ("D:\\Modis250\\NDVI_10dias_anom\\anom_{}_dec_{}.tif".format(y, d))
     NDVIAnom=arcpy.gp.Minus_3d(ndvi_year, NDVIMean, NDVIAnomOut) #Calculate the last year decendial NDVI anomaly and record the output tifs
     #NDVIAnom = ndvi_year - NDVIMean
     #NDVIAnom.save(NDVIAnomOut)
     #print ("Decade "+d+" of "+y+" ok")
     print("Decade {} of {} ok".format(d, y))
