Python Help - Downloading Images from URL
1365
08-30-2024 07:02 AM
aprhyde11
I'm pretty new to python but I'm using the following script to download images from links that live in the attribute table of my layer.
import arcpy
import urllib.request
import os
# Set the workspace
arcpy.env.workspace = r"C:\workspace\GIS.gdb"
# Define the feature class and the fields
fc = r"C:\layer_zip.shp"
fields = ["image_url", "id"]
# Define the output directory
output_dir = r"C:\Users\download"
# Loop through each row in the feature class
with arcpy.da.SearchCursor(fc, fields) as cursor:
    for row in cursor:
        photo_url = row[0]
        object_id = row[1]
        # Construct the file name using the OBJECTID or another unique identifier
        photo_filename = os.path.join(output_dir, f"{object_id}.jpg")
        # Download the image from the URL and save it to the output directory
        urllib.request.urlretrieve(photo_url, photo_filename)
print("Photos have been downloaded and saved.")
It will download several photos before I get this error message
URLError                                  Traceback (most recent call last)
In  [35]:
Line 25:    urllib.request.urlretrieve(photo_url, photo_filename)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\urllib\request.py, in urlretrieve:
Line 241:   with contextlib.closing(urlopen(url, data)) as fp:
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\urllib\request.py, in urlopen:
Line 216:   return opener.open(url, data, timeout)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\urllib\request.py, in open:
Line 519:   response = self._open(req, data)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\urllib\request.py, in _open:
Line 536:   result = self._call_chain(self.handle_open, protocol, protocol +
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\urllib\request.py, in _call_chain:
Line 496:   result = func(*args)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\urllib\request.py, in https_open:
Line 1391:  return self.do_open(http.client.HTTPSConnection, req,
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\urllib\request.py, in do_open:
Line 1351:  raise URLError(err)
URLError: <urlopen error [Errno 11002] getaddrinfo failed>
 Any help is appreciated!
Ben_Ba
I would suggest running the urllib.request in a try statement, that way the script doesn't hang on a single picture, and you can see if it is just one url or all of them that are problematic:
try:
except URLError:
     print(photo_url)
2.14.0.0
