Python code to replace individual characters using field calculator
3154
5
12-29-2021 12:08 PM
Labels (2)
MattCotterill
I need to replace the 3rd and 4th digits of street addresses with 'X' and strip any apt info from the end.
Fer example "1756 Cedar St 4D' should become 17XX Cedar St
The closest I've come is:
!USER_Address_Line_1!.replace('0123456789','X')[2:3]
!USER_Address_Line_1![2:3].replace('0123456789','X')
but those just seems to turn the entire address into a single digit number
To remove the apartments, I got as far as removing numbers at the end using
!USER_Address_Line_1!.rstrip('0123456789')
but that still leaves lettered apartment units
I'm using ArcGIS Pro 2.8 and Python 3
JayantaPoddar
Thy the following expression
Expression Type: Python 3
(!USER_Address_Line_1![0:-2])[:2]+'XX'+(!USER_Address_Line_1![0:-2])[4:]
or
((!Micromarket![0:-2])[:2]+'XX'+(!Micromarket![0:-2])[4:]).strip()
Think Location
JayantaPoddar
or
Think Location
MattCotterill
Thank you! In terms of what I need for this data set, this absolutely works. I'm curious how you would handle it if you needed to keep the street types (RD, AVE, BLVD, CT, TER, etc.) and not all addresses had apartments. Can you run an if/then loop in field calculator?
DanPatterson
MVP Esteemed Contributor
or generically... you can add the length check if you want
fld = '1756 Cedar St 4D'  # !fld!  or !YourFieldName! for the expression
def r(fld, subval="X"):
    new = []
    vals = fld.split(" ")
    for v in vals:
        for i in v:
            s = "".join([subval if i in "0123456789" else i for i in v])
        new.append(s)
    new = " ".join(new)
    return new
# -- test
r(fld)
'XXXX Cedar St XD'
... sort of retired...
MattCotterill
Thank you! This is a little over my head, but I feel like this is something I need to understand. By "generically" do you mean outside the field calculator environment, using a Python interpreter? And is that how I would run this script on a csv file?
DanPatterson
By "generically" it just doesn't replace 2 characters that are numbers but will replace any number whether it is a street address or an apartment number... even if there is no apartment.  The only issue is if you had a
"1st Avenue"
it would become "Xst Avenue"
This is a code block example
Calculate Field Python examples—ArcGIS Pro | Documentation
They are handy when a one-liner is too constrictive
