PyScripter doesn't accept ArcGIS Pro 3.0 Python environment
2590
07-26-2022 02:14 AM
HanliePetoors
I'm working in
• Windows 10 Professional X64
• PyScripter 3.6.3.0 X64
• ArcGIS Pro 3.0
After upgrading from ArcGIS Pro 2.9 to 3.0 PyScripter no longer accepts the ArcGIS Pro Python environment as a Python version. When I try to add the folder
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
as a version in PyScripter, I get the error:
"PyScripter could not find a usable Python installation at the specified path."
Does anyone know how to fix this?
Thanks
Hanlie
Chris_Matthews
I've got exactly the same issue. @HanliePetoors did you find a resolution?
HanliePetoors
Hi Chris,
Unfortunately not.
My workaround was to use a different Python Editor - I chose Thonny.
Regards
Hanlie
Chris_Matthews
Since posting the question I've found a solution, which was to upgrade PyScripter to version 3.6.4 x64.
HanliePetoors
Thanks, I'll give that a try.
Chris_Matthews
If you have a cloned python environment created in 2.9 you will need to upgrade that too (from the Package Manager in Pro).
