Publishing Web Map from Pro: An Error occurred loading this layer
1926
02-28-2022 01:21 PM
Brendle
Some of my most important layers are not publishing correctly from ArcPro to AGOL. A have a layer of ACS data that will not show up in the web map I am trying to make.
Before publishing, I used the "Analyze" button, predicted no errors. However, I keep receiving "An error occurred loading this layer".
Thinking this was a server issue, I tried again the next work week to find the same issue. I was previously receiving this error on two layers, but when I added all layers to the same file geodatabase in my project folder, the error went away for one layer and the layer appeared when published to a web map. The error still persists for this single layer, which is incredibly important to the map.
Can Esri add better error messaging for this error? I have no idea how else to troubleshoot because the error message is not descriptive.
RobertBorchert
Honored Contributor
What is the source of the ACS... data.  Is it from another online source?
Brendle
Hello @RobertBorchert , thank you for the reply.
I downloaded the ACS data locally as a shapefile from my state's open data website.
After adding symbology to the layer, I added it to the same file geodatabase as all of the other layers in the project.
This layer still will not load in AGOL as a webmap or as a feature layer.
