Publishing from ArcPRO
1235
03-10-2022 09:26 AM
by Anonymous User
Not applicable
We are getting a vary vague error for publishing. This was working and we have not changed or updated anything. Now getting error message failed to publish web layer.  No one can publish, we all get this error.  Any ideas on what we can check? We did try to republish data we have already published so its not the data or formatting.
When checking the Enterprise, it publishes the service definition fine. But it fails on the layer.
ArcGIS Server 10.9.1 and ArcPRO 2.8
Thank you,
Annette
by Anonymous User
Not applicable
@jcarlson We just resovled the issue. We had to reconfigure permissions on the folders and restart publishing services. It works now. Very strange.
jcarlson
We see this from time to time. Are you overwriting a layer? That's when we see this message the most. If not, what is the source of the data? We have also seen cases when a query layer was being published and there was a slight problem in the query statement that was not flagged prior to publishing, but which prevented the layer being published.
- Josh Carlson
Kendall County GIS
by Anonymous User
Not applicable
CWright
We had a similar issue this week.  One of the layers had z-values enabled while the rest did not.  The layer with z-values only had one feature so we removed it and successfully published.
