Project() tool intermittently fails?
335
01-16-2026 09:14 AM
AlfredBaldenweck
MVP Frequent Contributor
I'm making a workflow that involves reprojecting a blank template into a different projection, then appending stuff in. (In a loop because I do this multiple times)
Where I'm running into problems is that Project() will randomly fail. Same input data every time since I'm just testing for now.
My best guess is that the workflow is moving too fast maybe? It fails midway through the process. If it were a consistent thing I'd be more ok with it, but it's the exact same data every time, but 2/5 runs will fail on the Project() step.
Has anyone else had this sort of thing happen?
