Processing LiDAR from .xyzi
1937
05-09-2019 09:38 AM
JamesStewart-Moore1
I have been given some LiDAR that needs to be processed. The file-type is .xyzi, which I understand to be ASCII. Doing a little bit of research directed me to the ASCII 3D to Feature Class. My assumption is that it needs to be brought in as point features and that then I can interpolate those points into a TIN, which I can then be processed into a DEM. Is this the best way of going about this?
Tags (4)
CodyBenkelman
Look here http://links.esri.com/3dsamples for the tool ASCII text to LAS
With a LAS file you can then run LAS dataset to Raster to generate a DEM.  Note if your XYZI points represent "all returns" (not ground only) and you're seeking a bare earth DTM, you'll have to run Classify LAS.
For ongoing help post in
https://community.esri.com/groups/lidar-resources
CodyBenkelman
JamesStewart-Moore1
Thanks, Cody. I ultimately used LAStools' "txttolas" tool. I was not aware that there was a tool within Arc that did the same thing. I appreciate your response.
