Problem with Summarize elevation
3692
7
09-07-2021 05:49 AM
LucieBaránková
Hello,
I am using ArcGIS Pro, version 2.6.0
I have problem with summarize elevation tool. I have three datasets and two of them worked without problem, just with the third I´ve got error messages:
File "Y:\Tools\Elevation\scripts\sumelevation.py", line 621, in execute
in_mem_out = self.computePointStats(tempOut, feature_id_field, dem_resolution, "all", feat_desc.ShapeType, feat_count, inputExt)
File "Y:\Tools\Elevation\scripts\sumelevation.py", line 318, in computePointStats
arcpy.CalculateField_management(zone_features, "MinElevation", "CalcVal(!SHAPE!, '{0}')".format(dem_layer_elevation), "PYTHON", calcValFunction)
File "c:\program files\arcgis\server\arcpy\arcpy\management.py", line 3647, in CalculateField
raise e
ExecuteError: ERROR 000539: Error running expression: CalcVal(GPVARIANTOBJECT0, 'D_24m_sumelev')
File "<expression>", line 1, in <module>
File "<string>", line 5, in CalcVal
File "c:\program files\arcgis\server\arcpy\arcpy\management.py", line 17279, in GetCellValue
raise e
ExecuteError: ERROR 000622: Failed to execute (Get Cell Value). Parameters are not valid.
ERROR 000628: Cannot set input into parameter location_point.
Failed to execute (CalculateField).
Failed to execute (SummarizeElevation).
Failed.
Does anyone know what to do with this? I checked the data set and everything is in the same format as the previous two datasets that worked well..
Thank you very much
Thank you very much
David_Brooks
MVP Regular Contributor
@LucieBaránková convert to TIF and try again. FGDB rasters aren't the optimum medium for raster analysis.
David
..Maps with no limits..
JayantaPoddar
How many features are there in the Point Layer?
The maximum number of input features is 1,000. If more than 1,000 input features are provided, the tool will return an error and will not execute.
Think Location
LucieBaránková
Hello, there are only 25 features, so this should be ok. I am just a little bit confused because the first error says "line 621,...". There is no line 621 in my dataset.
JayantaPoddar
Could you restart ArcGIS Pro and give it a try again?
Think Location
LucieBaránková
That was the first thing I did 🙂 did not help
David_Brooks
@LucieBaránková run check geometry and, if necessary, repair geometry. You may have empty geometries in there.
David
LucieBaránková
Ok I will try it, thanks 🙂
