Pro3.1 - Insert multiple images into map so that each image can be sized & rotated individually
1205
03-09-2023 01:16 PM
KeithAddison1
I have several hundred small images that represent signs.  I need to inert them into a map.  They don't need to be GIS features, just dumb graphics.  I can't do it the simple & obvious way with graphic layers because they are limited to 10MB sum total in the map.  The needed images sum to around 200MB in total.  I also need to rotate & size each of these images independently.  I tried making a picture marker style, but I can't rotate & scale each image instance independently this way - changing the orientation of one changes them all.  These are not simple images that can be composed by putting together a bunch of tiny shape markers, ie doing this several hundred times over again:
There has to be a way to do this, it seems such a mind numbingly simple thing to ask.
