Pro Schema Locking
2728
05-30-2019 07:30 AM
roemhildtg
Anyone know if there's a way to clear a lock on a fgdb in pro without restarting the whole program? I close out  of any active maps that use that fgdb, I refresh catalog tree, but nothing seems to "unlock" the database. Just curious if people have similar experiences or have a workaround. Closing/restarting pro takes a good chunk of my day it seems and I'd love to find an alternative. I can't find any way to remove the lock other than a full shutdown of pro.
More details:
 - A standalone python script I'm working on in Jupyter throws a schema lock error
 - There is a lock file in the file gdb I'm working with
Removing the layer from the map looks like it clears the lock, UNLESS I have browsed to the layer in the fgdb through the catalog pane. If I first connect to it via the catalog panel in Pro, then removing the layer does NOT remove the lock.
KoryKramer
Esri Esteemed Contributor
What version and patch are you running?
roemhildtg
ArcGIS Pro 2.3.3
MervynLotter
MVP Regular Contributor
Although I am not using python (you could probably still try and code this), I frequently encounter schema lock issues when using Field Calculator and by simply selecting Enable Undo this allows me to complete the calculation 90% of the time.
JohannaPrüssmann1
Thanks Mervyn! Worked like a charm. I've been struggling with this issue for a couple of months now. I always had to close Pro, do the field calculations in ArcMap and the go back to Pro. I'm so glad that with your help that's over now.
