Pro Parcel Fabric Feature Service Issue
2133
07-17-2019 12:53 PM
MichaelSnook
Hi All,
I am attempting to experiment with the new Parcel Fabric in ArcGIS Pro and running into some issues with the feature service.  It seems to work the first time I publish the service and added the Fabric to a new project.  Editing seems to work as expected but typically, when I attempt to re-open the project the fabric will appear with red exclamation marks next to all of the layers.  If I try to add it back to a fresh map I get a 'Failed to add data: 0' error.
I can republish the service and the fabric in the original ArcGIS Pro project will load again fine.
Any ideas?
FYI - running ArcGIS Server 10.7.1 on one machine federated with Portal on another machine.  The fabric is stored in PostGreSQL 11 running on my local machine (for testing purposes mainly).
Thanks!
AmirBar-Maor
Hi Mike,
You are ahead of the game!
A map can only contain one parcel fabric and perhaps you are seeing it because you are trying to add a second parcel fabric to the same map?!
In any case - it would be good to log issues you suspect as bugs with technical support so we can track and fix any bugs.
I assume you are using ArcGIS Pro 2.4.
Amir
MichaelSnook
Hi Amir,
I am not attempting to add a second fabric to the map.  It happened again this morning when I opened my saved project with the published fabric in it. If I click one of the red exclamation marks it gives me a 'Cannot connect to datasource' message/error.  When I attempt to re-add the fabric I do that from a brand new 'Start without a template' project in Pro.  I am on 2.4.  When I re-publish the fabric it comes back to life.
I'll put in a support ticket.
Mike
MichaelSnook
I was finally able to install PostGres on another server rather than my local machine and this issue has gone away. I still cannot connect to the fabric service from the postgres instance on my local machine more than once (after a restart of my machine).
AmirBar-Maor
Michael Snook- the technical support analyst is trying to get a hold of you for the last 2 weeks to get to the bottom of this. Please get in touch with him.
MichaelSnook
Hi Amir,
Yes, we put the case on hold about a week ago and I emailed the support analyst via my case number mail thread once I tested this out and got it working...waiting to hear back to see what's next.
Thanks, Mike
