Pro - New Project Dialog Box - Adding local connections to exist upon every session
1473
07-18-2017 07:56 AM
BrianDudek1
I would like a reminder on how to add default folder connections under Computer when creating a new project   See image.  I have done it before as you can see,  but this was forever ago (I forgot how I did it), and I would like to create a connection further into directories that are there for any new project I might create.
DanPatterson_Retired
From here... apparently make it a 'Favorite'
If you add the same folder to many projects, favorite that folder to simplify the process. The project favorites collection is always available. Add a favorite folder to projects where you need it without having to remember its location. You can add a favorite network share to every new project you create. If your user profile supports roaming, favorite folders will be available on every computer you use.
so it work? saw your 'like' but you didn't comment
