PRO - BIM Building Filter not showing all values
584
09-03-2025 10:02 PM
LaurenAlt
Hi All, using Pro 3.3.6 with a BIM revit model that I have converted to a geodatabase. I created a building layer and imported into a local Pro scene.
I have added an attribute column to all of my layers to show a condition assessment (short). Some of the items have values (1-7), but not all of the items have a value, so the remainder were <null>. When I tried to create a building filter to show the condition assessment, the values column was empty. Only "GenericModel", "Slabs", "Columns" and "Beams" currently have some items with a 1-7 value, but I can't get it to show in my filter values. I went through all of the layers and changed <null> to 99. Now I have 99 as an option in filter values , but not 1-7.
Interestingly, in "architectural - roofs" if I change the attribute values in the first seven items in "conditions" column from 99 to 1 to 7, then they show up on the filters values list, but when I change them back to 99, then only 99 is shown. Is this a bug, or can any one assist?
LaurenAlt
As always seems to happen, I found the issue 5 minutes after posting this question. For all the players in the room, one of my attributes was set to type "long" whilst the others were set to "short", so I caused a glitch in the cortex... So, note to all, make sure all of your columns are of the same type to get the filter to work. 🙂
LaurenAlt
