Pre-set templates not stored in web map
265
11
2 weeks ago
HanliePetoors
I'm working in ArcGIS Pro 3.6.1 and Enterprise 11.5 and we have a Utility Network published as a service.
I would like to make pre-set templates available to 60+ editors of the network.
The only way I could get this to work was to create a layer package for the base feature of the pre-set template. Then I added that to a web map in ArcGIS Pro, and then I created a Project Package for sharing through Portal.
I could not get the pre-set templates to save to the web map no matter what I tried.
I also tried enabling Shared Template Editing in the service, to no avail.
Has anyone managed to store a pre-set template for features coming from a service in a web map? If so, could you share your workflow please?
Thanks
Hanlie
CraigGillgrass
Good news the Group templates are working.  That points to something specific in the Preset templates.  This looks like could be a publishing issue - at this point, you're best path forward would be to contact Technical Support and have them troubleshoot it with you.
HanliePetoors
Thanks I'll give that a go.
