Potential bug: ArcGIS Pro 3.1.3 clears entered parameters from Python Script tool
1050
12-27-2023 02:22 PM
Labels (2)
EmmaHatcher
We're running into an issue at our organization where Python tools built with ArcGIS Pro 2.9.7 will run for a user in ArcGIS Pro 3.1.3, but it takes several attempts to actually get the entered parameters to stick. Clicking run or even clicking another text box for another parameter will make prior entered values clear/drop.
All the parameters for the particular tool are text input.
After selecting run or sometimes selecting another input text box for another parameter:
Has anyone else run into this issue in ArcGIS Pro 3.1+, or was there a change to tbx files in ArcGIS Pro 3.1 that might explain this? We haven't tested in toolboxes created in ArcGIS Pro 3.1+ continue to have the issue- it may be a slight compatibility problem.
