Polynomial coefficients in Raster Calculator
1260
08-23-2021 11:07 AM
jpharris855
I was wondering what (if any) syntax would be used to incorporate the coefficients from a polynomial independent variable into a Raster Calculator equation. For example, if you wish to show a unimodal response to elevation, the syntax in R would be response~Elevation+I(Elevation^2). Is this possible using Raster Calculator? If not, is there another tool available to achieve this result? Thanks in advance.
DanPatterson
MVP Esteemed Contributor
A quick tour of using Map Algebra in Spatial Analyst—ArcGIS Pro | Documentation
How Raster Calculator works—ArcGIS Pro | Documentation
and
An overview of the Math toolset—ArcGIS Pro | Documentation
will cover a basic introduction in using raster data and raster "math" if you are transitioning into doing this within a gis environment.  It is basically the same principles
... sort of retired...
