polygon to raster error999999
2570
6
12-07-2022 05:32 PM
MingHan
arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (PolygonToRaster).
MingHan
Here is the example data and script. It is very weird to me. Any one can help? Thanks
MingHan
Hmm, problem solved by remove ".tif" ........
DanPatterson
MVP Esteemed Contributor
Did you specify a folder for the output of the *.tif or was the output going to a geodatabase?
*,tif files must go into a folder.
... sort of retired...
MingHan
I did, thanks for the reply. I avoid this problem by saving output to gdb
SteveLynch
@MingHan  which version of ArcGIS Pro are you using?
MingHan
thanks for the reply. I avoid this problem by saving the output to gdb. I used the latest version.
