Polygon label appear only inside hole
2823
03-31-2017 10:36 AM
RichardHughes2
The label for a polygon I just created in only appearing inside a hole in that polygon.  The label is set to avoid holes in polygon, and the label is set to only draw inside polygon.
Is there a setting that I am missing?  Surely it's not a bug?
RichardHughes2
As a resolution to this thread, I performed a Repair Geometry on the layer in ArcPro.  This image shows that there was an issue with the ordering of polygon rings.  The label now appears correctly.
Repaired Geometryfixed
IanMurray
Honored Contributor
A screenshot of how the feature is being labelled, along with your placement properties would go a long way towards helping you solve this.
JayantaPoddar
What happens if you turn on Maplex label Engine? Label with the Maplex Label Engine—ArcGIS Pro | ArcGIS Desktop
Could you attach screenshots?
Think Location
RichardHughes2
These are some screenshots showing the issue in ArcPro.  Thank you for taking interest.  In all likelihood the issue is caused by the CAD data from which this GIS data was created.  Possibly because the vertices are out of order.  Just a guess though.Label in Polygon HoleLabeling Settings
JayantaPoddar
Thank you for the details.
There could be a geometry issue. Try repairing the geometry.
Checking and repairing geometries—Data Management toolbox | ArcGIS Desktop
Repair Geometry—Data Management toolbox | ArcGIS Desktop
Think Location
RichardHughes2
