Polygon Centroids not displaying
5012
04-04-2022 12:07 PM
Labels (3)
CarbonAmerica
Hi everyone,
I'm currently mapping parcels within Nebraska, but their GIS platform did not have a quarter section shapefile. Therefore, I need to calculate the center of each square section. I attempted to do this through the calculate geometry option in the attribute table by creating an X and Y field, and selecting "Centroid X Coordinate" and "Centroid Y Coordinate" respectively. I then exported the table and tried to add it to my map using the Display XY Data. However, I get these warnings and nothing shows up:
Can anyone tell me why the points aren't showing up? I also attached a screenshot of the attribute table in case that's helpful.
Thanks so much!
XY Table To Point
Parameters
Input Table CentroidTable
Output Feature Class C:\Users\rachel.fanch\Documents\ArcGIS\Projects\Bridgeport\Bridgeport_Landowners\Bridgeport_Landowners.gdb\CentroidTable_XYTableToPoint2
X Field X
Y Field Y
Z Field
Coordinate System GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98315284119521E-09;0.001;0.001;IsHighPrecision
Messages
Start Time: Monday, April 4, 2022 1:02:52 PM
WARNING 120251: The following fields are not supported and will be dropped: Shape_Leng, Shape_Area
WARNING 100160: Some of the features have invalid geometry and have been removed from the result
WARNING 000192: Invalid value for rows: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, etc.
Succeeded at Monday, April 4, 2022 1:02:55 PM (Elapsed Time: 3.63 seconds)
Thanks so much
DanPatterson
The X and Y values are in a projected coordinate system, not a geographic one (GCS).
Specify the appropriate projected coordinate system.
... sort of retired...
DanPatterson
CarbonAmerica
This worked, thanks so much!
Thanks so much
DanLee
by Esri Regular Contributor
Perhaps you could just use Feature To Point tool to get the centroid points directly.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/feature-to-point.htm
