Points to Path: Possible in Pro?
2558
09-30-2019 06:47 AM
ThomasColson
MVP Alum
The create points to path, where the points will have a unique ID denoting that n number of points belong to the same path, is oft discussed yet never clearly answered, with the defunct and not-allowed-to-install Hawthes tools often cited as a solution. Has anyone figured out how to do this in Pro? What I have is several hundred thousand pings from several thousand aircraft transponders, need to convert those points to paths showing direction of travel.
creating animal movement paths
Mapping points and connecting them with a line - mapping westward migration.
joining  points to make a line
The goal is to join point data to lines.
How To: Create connection lines between two points
Is Points To Line the solution here?
JoshuaBixby
How is the data structured and what are you looking for, specifically, in the results?  Obviously a path, but what kind of attribution on the paths.
DanPatterson_Retired
sequential points would make it too easy
Points To Line—Data Management toolbox | ArcGIS Desktop
