Points to Line - branches to a single point
1087
10-18-2023 07:53 AM
JamesTayloruk125
Hi all,
I'm trying to figure out how to optimise something (I have figured out how to edit vertices and continue feature, but doing so repeatedly is not ideal)
Q1 - how do I make separate lines converge to a single point?  is there a best way to configure the 'string' and 'order' attributes in the table below? or is there a better way of doing this?
I have used the following format to create the separate lines:
Points are the numbers of each point, string is a differentiator to create multiple lines, order is the order which the points are connected and diameter is just so I can colour code the lines eventually.]
it spits out something like the below, where the final lines don't connect to the node.
Q2 - Is there a way of, similar to the above, is there a way to connect the below drains in the configuration: 1-2, 4-3, 3-2, 2-Node.  It currently seems to connect 1-2-3-4-node but drain 2 should be a branch.  I also have the same issue with the branch not connecting to the node as per Q1.  This is all on the same map.
Any help would be amazing! just dipping my toes and learning this amazing tool!
DanPatterson
you need and origin and destination point for each segment
node - 1, node -2, node-3 etc
or however you intend to formulate what you need
... sort of retired...
