Points missing when converting large CSV table to XY Points
1438
02-24-2023 04:06 AM
CaoimheMoy
I have a huge dataset of housing data which I am trying to upload to ArcPro and then convert to points using XYData.
Every time I convert the data using XYData and the points are created and displayed on the map, there always seems to be points missing, When I cross-reference the dataset and look for the missing points, I always find the data in the table but it hasn't converted.
When I open the uploaded tables to Arc, all points have been uploaded when compared to the initial file. The issue seems to be when I use the 'Display XY Data' function to convert to points.
The dataset being used is very large, each table having 1,000,000+ entries, is there an upper limit on how many rows Arc will convert at any one time? I cannot open in excel and split these files manually as excel also has an upper limit as to how many rows it will allow open in one workbook.
Is there a function other than 'Display XY Data' that I can use to convert the table to points on the map? Any help would be greatly appreciated!
DanPatterson
MVP Esteemed Contributor
Did you try
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
make the destination for the inputs a file geodatabase
... sort of retired...
DanPatterson
Did you try
