Point to Nearest Polygon
11723
21
02-07-2018 06:22 AM
MatthewNickeson
I have a map with a layer of point locations throughout the US and a layer of polygon sectors. All of the US is contained within a sector. I am trying to find the closest polygon to each location by driving distance and driving time. I haven't been able to find the functionality that will allow this analysis since each location is contained within a polygon. Does anyone have any insights whether this is possible and if it is how it could be done?
MatthewNickeson
I have been thinking about my problem and believe that your approach would be the best approach. I was hoping you could provide a little guidance as to how I would treat the roads as lines. This would be hundreds of thousands of points to it is obviously not able to be done by hand.
XanderBakker
Esri Esteemed Contributor
Some pointer to get you started:
MatthewNickeson
Thank you everyone, you have all been awesome! I’ll give your suggestion a go tomorrow. I’m only 3 weeks into my arcGIS experience and I really appreciate the community’s willingness to help.
RebeccaStrauch__GISP
Matthew, make sure to come back to thus thread and mark one answer as correct, and others as helpful to get to that point.  That will help other in the future and will close out the thread.  A summary is always nice too.  Interesting topic/problem.
MatthewNickeson
Thank you Xander and Dan, your suggestions are very helpful. I apologize for what is probably a novice question but I'm not sure how to get the roads as an input feature to the intersect. I should clarify that I have Pro Advanced with Spatial Analyst but not Network Analyst. I was incorrect when I stated that earlier. I would prefer not to purchase the Network Analyst extension but can if needed.
XanderBakker
XanderBakker
When the distance between the large polygon and the points of interest is high, you could select only the highways the cross the border of the polygon to simplify the analysis, since the route will most likely use main roads to get to the point. In that case there would be no need to include the smaller road in the process to define the points that represent the intersections between roads and the polygon border.
JakeSkinner
Hi Matthew,
If you have an ArcGIS Desktop license you will have an ArcGIS Online subscription.  Not sure if you, or anyone in your organization, has activated this, but if so you can use the Find Nearest analysis tool.  You can specify Drive Times as a the measurement.
Note:  This tools will use credits.  With 3,500 points you will be charged 1,750 credits to perform this analysis.
MatthewNickeson
That was my initial inclination to try but it results in an error. The program indicates that the nearest location field must be a point for driving distance when I attempt to run it as such. My nearest location is a polygon which is the crux of my issue.
XanderBakker
How large is the polygon and what does it represent?
