place Feature-labels outside, around 2nd layer's polygon
2869
09-13-2023 07:31 AM
Thomas_van_Offeren
I've a map with two layers.
One with the Features I'd like to place the Attribute-labels from.
And a second layer with the project-area (red striped).
Now I'd like to have the labels from the Features in the first layer placed (just) outside and (like a clock) around the polygon of the (red striped)  second layer, with a call-out stripe to the Feature.
Preferred offset does not take the location of the Feature in the projectarea into account.
Land Parcel Placement, River placement, Boundary placement is all about the Feature's. Not the second layer.
Close is the Regular placement: External zones. But that makes all the labels go to the left, top, right or below the second layer (on a preferred offset). It does not 'go around' the second layer.
Any ideas?
Tags (3)
AdrianWelsh
MVP Honored Contributor
The leader line's anchor can be moved, if that's what you're asking:
https://pro.arcgis.com/en/pro-app/latest/help/editing/add-or-remove-a-leader-line.htm
It doesn't have to be a straight line either. Here is a crazy example of curved lines and lines with the engineering bend in them:
AdrianWelsh
Labels are fun... When I come across really specific labeling like this, I find that my best solution is to convert the labels into annotations so that I have full control of where I want them to go.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/converting-labels-to-annotation.htm
Thomas_van_Offeren
Thanks for the advice to take a look at annotations. I had a quick peek and
wondered whether or not it is possible to move the callout line around the
annotation? It looks likes it is fixed to the annotation?
AdrianWelsh
AdrianWelsh
Leader lines have these options:
