Permission Error
4188
11
08-18-2021 02:51 AM
HamzaM
I am trying to publish my Object detection model but when i run this code to publish it
model.save('Building_footprint_10epochs', publish=True)
i get this error
@JayantaPoddar @DanPatterson @jcarlson @Tim_McGinnes @JoeBorgione @TimOrmsby @ShaunWalbridge @lamyaaghadiry1
Tags (3)
DanPatterson
MVP Esteemed Contributor
Did you try the standard project save, shut down, restart and retry the save?
... sort of retired...
HamzaM
I saved it locally but i want to publish ARCGIS Online so other people in my organization can use the model.
DanPatterson
So it may be an AGOL issue then
HamzaM
What do you mean by AGOL ?
DanPatterson
arcgis online
by Anonymous User
Not applicable
Are you able to publish it using the web interface of ArcGIS Online ?
HamzaM
It is in ARCGIS Pro notebook, i want to publish it to arcgis online to be able to share it with people in my organization but i am not able to publish it and once i close arcgis pro i lose the model and have to run the notebook again which takes a lot of time.
If there is a method to share it from my notebook to arcgis online can you tell me the steps?
HamzaM
which one do i choose to add the model
I tried the choose an item from my device and choose the .dlpk model but it didn't work so which extension do i use.
HamzaM
It worked through ArcGIS Online with .dlpk extension.
