PDF Question
2105
03-06-2024 11:04 AM
DEAF_PROBERT_68
Honored Contributor
Are we able to view PDF files within ArcGIS Pro Catalog Pane or View ?
If yes, then how ?
DanPatterson
MVP Esteemed Contributor
No.  It only lists files you can open/use.
... sort of retired...
BarryNorthey
You can convert PDFs to TIFF files as a workaround using the PDF To TIFF GP tool.
DanPatterson
or just use Windows File Explorer to open them, and save a conversion if your intent is to preview files.
DEAF_PROBERT_68
Honored Contributor
What I am trying to say here is in ArcCatalog and you can add a pdf file there and then when you double click on a file it opens for you ... So I guess it would be nice if you have it in ArcGIS Catalog Pane or View to click on that file and display it....
Otherwise Thank you for the tips
Robert_LeClair
Esri Esteemed Contributor
Currently, this is not supported in the Catalog View in ArcGIS Pro.  On the Supported data types and items -> Files supported as inputs or outputs, it does mention PDF as available on the browse dialog boxes but are not available in the Catalog Pane or Catalog View.  There is a ArcGIS Idea here you can upvote to get more views/traction with the development team.
