PDF export shows raster outline
2113
12-01-2020 04:43 PM
EllenSaxon
When I export a PDF map with raster imagery tiles overlapping, the PDF comes out with an outline of the rasters. See attached screenshot. I have tried adaptive and JPG compression with no luck.
Using ArcGIS Pro v 2.6.3
Tags (3)
DavidPike
MVP Notable Contributor
is this from a mosaic dataset (do you have overviews etc.?), and does it look colour balanced when viewing?
Sometimes having a stretch on the renderer can output stuff like this, or stretch calculated from current display extent.  try it with no stretch at all.
EllenSaxon
Hi @DavidPike
No this is not mosaic. They are aerial imagery tiles of different resolutions. I sit the finer resolution (0.149mpp) over the more coarse tiles (0.299mpp).
mpp = meter per pixel
When this is done in arcMap or exporting to jpg from arcGIS Pro the overlap is seamless (if the imagery is from the same date)
