PC Freeze with Pro
828
09-24-2025 09:54 PM
Y_Chau
ArcGIS Pro freezing is nothing new. Normally I would kill it and restart the app. But this time it froze my PC. It happened after I tried to change symbology. Symbology pane displayed this never seen before message in yellow (attached). This was followed by a complete system freeze. After some time the PC started to whir still staying frozen. Even Ctrl+Alt+Delete doesn't work.
Anyone else?
ChrisUnderwood
Hello @Y_Chau
This Esri Knowledge Article shows exactly the error message you are seeing. Do any of the solutions or workarounds offered resolve the issue for you ?
https://support.esri.com/en-us/knowledge-base/error-requested-operation-could-not-be-completed-00002...
Y_Chau
Hi @ChrisUnderwood
The message itself is not a problem. I got it again and it goes away when i restart Pro. The problem is that the first time when it appeared my PC became unresponsive. I had to push the power button to turn it off and then on. Hasn't happened again since then.
