Partial Aerial Printing Issues
1930
12-06-2018 10:31 AM
by Anonymous User
Not applicable
Hello!  I have been using ArcPro for a while now to print customer aerial maps with no issue.  Today I go to print and it is only printing a partial of my aerial image.  I tried 3 different printers with the same results (2 HP plotters, 1 Canon). I can export to PDF or JPEG without issue but when I print only a partial image is printed.  Has anyone run into this?  I like printing from ArcPro our large scale aerial maps due to the speed of spooling (2 minutes in Pro vs 20 minutes in Desktop) but will have to switch back to Desktop if I can't fix this.  I am using ArcPro 2.1.
FYI - I did remove the aerial imagery and complete re-add it in case that was the problem.  But it didn't fix it.  I removed it from a project in ArcPro and add it to a brand new one with the same results.
Thanks!
Leesa
by Esri Contributor
Hi Angelia,
This sounds like it might be a bug, and we'd like to take a look. Is there a chance you could share your data here so I can try to reproduce the problem?
