Parse Path is including raster extension with "_"
1767
11-16-2023 10:26 AM
NoahWasserman
I'm trying to use the Parse Path utility in Arc Pro 3.1.3 Model Builder but the tool is including the extension in the Name output. I've tried selected or unselecting the "Format Name, Extension and Workplace" option but I'm still getting the "_asc" which is causing an error when I try to use this for a field name:
Input: .../raster2010apr.asc
Parse Path Name: raster2010apr_asc
In ArcMap the Parse Path utility gives the correct "raster2010apr" as the Name out put but not in Pro.
NoahWasserman
It seems that the order in which you add in Parse Path matters.  If you add in Parse Path to a blank Model Builder and then add in your layer(s) it seems to exclude the file extension and give you a clean "%Name%".  Whereas if you add in Parse Path to an existing Model Builder that already has operations and layers in it then the outputs will include "_path".
DanPatterson
MVP Esteemed Contributor
There is the new tool
Parse Path (ModelBuilder)—ArcGIS Pro | Documentation
and the deprecated tool
make sure you are using the right one, since the syntax may differ
... sort of retired...
NoahWasserman
I'm using the one available in the Model Builder "Utilities" drop down.  I just did another test, if I have  "test.tif" as my input and 1) use %Name% in the output function without Parse Path the output is literally "%Name%.tif" and 2) when I use Parse Path I get "test_tif" even with the "Format Name, Extension and Workspace" selected. Using %Name% works in the ArcPro batch function but I need to run multiple steps for 3000 rasters and have to ultimately add the file name as a field name to a zonal statistics table (<13 characters, which it won't be with the "_tif").
NoahWasserman
