Parcel Drafter No Longer Works
1042
10-23-2025 06:48 AM
ThomasGoodridge
It looks like Parcel Drafter is no longer available, is there a way to take all the layers that were created in the Parcel Drafter Solution and just do the same thing in ArcPro? I'm using it to make sure surveys close properly.
Tags (1)
Robert_LeClair
Esri Esteemed Contributor
There is a Traverse tool in ArcGIS Pro that enables you to create a parcel using metes and bounds descriptions.  I have not worked with the Parcel Drafter widget personally so don't know if this fully meets your needs or nots.  There are some rumblings of building this in the ArcGIS Experience Builder, maybe, in the following articles:
Parcel Drafter Widget?
Mature Support Notification: Parcel Drafter - Esri Community
ThomasGoodridge
Does the Traverse tool let me edit existing parcels, or continue an existing line feature? It's important to be able to see what the distance and bearings are.
Robert_LeClair
@AmirBar-Maor - are you able to assist @ThomasGoodridge with the question of the Parcel Drafter and it's replacement?  Thank you!
ThomasGoodridge
How do I adjust the rotation of a traverse? It keeps veering to the right.
