Pan sharpened image appears in the wrong location
1093
10-14-2025 01:40 AM
SimonCrutchley
I’m working with satellite data in Pro and I have problem. I have both M/S and Pan imagery, for which I’ve used the default projection, but when I use the Raster function to create a pan-sharpened image, it appears in the Atlantic. I leave all the default settings in Pan-Sharpen, so I can’t see what I’m doing wrong.
Unfortunately, I can’t share the imagery, but I’ve tried several images, all with the same result. Is there a basic user error?
Thanks
DanPatterson
MVP Esteemed Contributor
Does the arctoolbox tool
Create Pansharpened Raster Dataset (Data Management)—ArcGIS Pro | Documentation
do the same thing, if you explicitly set the output coordinate system in the tool's Environments tab?
... sort of retired...
DanPatterson
SimonCrutchley
Hi Dan, No, this is in the right place. I can obviously keep using this, but I just wonder what has gone wrong with the other tool?
Thanks
DanPatterson
Simon, I suspect that the raster functions may default to the coordinate system of the map rather than specified via the Environments tab.  I didn't see any Bug listed on the public facing Support site, but it doesn't mean that it doesn't exist.
In short, I always used ArcToolbox tools because of the Environment settings, which can be checked and set which isn't the case otherwise.
SimonCrutchley
Thanks Dan. I'll bear that in mind in future. 🙂
