Overwrite Web Layer Error: Field Shape_Length cannot be used as a display field
12358
5
04-04-2022 12:27 PM
MattCotterill
I've just upgraded to ArcGIS Pro 2.9.2 from 2.3.X. I'm trying to overwrite a web feature layer as I've done several times before, but I'm getting a new error. For the RPP Areas Layer, I get the error message "Field_Shape_Length cannot be used as a display field." The problem is, I'm not using that field for the label feature or symbology. I'm labeling on the "Area" field, which is a text field, using single symbology, and I'm not varying the symbology by any attribute. I've even tried changing the name of the "Area" field to "Zone". Any ideas?
KenBuja
Open the properties of that layer and select the Display section. That's where you set the Display field.
KenBuja
MattCotterill
Thanks!
DimityBoggs
My goodness thank you, this post saved me a world of frustration.
RikiKobayashi
Thank you, was about to make a post with the same problem!
ScottJones1
AHHHH!!!!! thank you so much!!!!
