OLE DB connection to SAS data
1056
08-01-2022 08:10 AM
JohnJinkins
Can use SAS Bridge to ESRI successfully to make a map in ArcGIS Pro 2.9.3.  But when I export the map to a PDF the SAS data does not seen to export along with the other parts of the map and as a consequence the PDF  lacks the  needed symbology.  Then when I save and then reopen the file the connection to the SAS data is broken and I have to rejoin the SAS data to the map to make it display correctly.
Getting messages about "encrypted password=000200" but don't know what PW that refers to, I'm thinking that encryption is causing the problem.
I attached a  PDF showing how I set up the OLE DB, any guidance appreciated, we've used the connection to SAS data extensively with ARCMap and I'd hate to not be able to use it with ArcPRO.
John Jinkins
