Old ArcMap Model properties (iterations) in ArcGIS Pro ?
1031
10-18-2022 01:06 AM
Labels (2)
HaydarHussin
Dear all,
Where can I find in ArcGIS Pro the iteration options that used to be part of the Model properties in ArcMap. For example the options "Run the model the following number of times:" or "Run the model until the variable is false:". See the image below. Are these options now part of the iteration tools in the ArcGIS Pro Modelbuilder ?
Best regards,
Haydar Hussin
DanPatterson
MVP Esteemed Contributor
I suspect `whie` or `for` is what you are after
While (ModelBuilder)—ArcGIS Pro | Documentation
... sort of retired...
