Obtain upstream downstream structure
1630
02-10-2021 12:45 PM
Labels (2)
MingHan
Hi Everyone
    Here is a stupid question. I have delineated a watershed into several catchments. some catchments do not have a stream.
    How could I obtain upstream and downstream structure?
Ming
DanPatterson
are you following these help topics?
Watershed (Spatial Analyst)—ArcGIS Pro | Documentation
How Watershed works—ArcGIS Pro | Documentation
Did you use pour points?
... sort of retired...
MingHan
That exactly what I did. I could obtain catchment which is the output of the Watershed function.  What I need is the upstream and downstream structure of these catchments. For example catchment 1 drainage to catchment 2; catchment 3 drainages to catchment 10;.....
I noticed that the stream link can provide this information. But in my case, not all catchment has streams
Ming
MingHan
I guess my question is that is there any function similar to StreamToFeature, but the input is catchment raster not stream raster?
