Now that Pro 3.4.2 has been released what issues do people still have that are not yet addressed?
6703
15
01-30-2025 04:06 PM
RTPL_AU
The title says it all.
EDIT: Maybe it doesn't.
What issues are you experiencing in Pro 3.4.2 that did not exist in 3.3.x or earlier?
I have a quiet few days ahead so want to know what issues you are experiencing with ArcGIS Pro 3.4 (that have not been addressed in 3.4.2)  before I upgrade from 3.3.2
There are so many bug fixes going from 3.3.x to 3.4 that I was quite wary to jump into 3.4 immediately. The old 'when fixing everything you're going to break something'....
There have been mentions of PDF issues elsewhere - sort of a deal breaker for me as a lot of projects I intersect require PDFs for static reports, submissions, etc.
No mention of desktop-side PDF fixes in 3.4.2 hence this post.
I wish Esri was more open about known/reported issues but I understand why they aren't.
Robert_LeClair
Esri Esteemed Contributor
I understand the question - thank you.  I was responding to your last sentence about known/reported issues and bugs.
The intent of the links was to show what bugs are reported/fixed with each update to ArcGIS Pro.  Related, on the Esri Support Services site - there is a BUG site for ArcGIS Pro (lists 15179 bugs as fixed, under consideration and so on) and other products you can use to search for logged bugs - Esri Support Search Results
In addition to filtering bugs, one can escalate a known bug through their My Esri account.
Let me know if you have additional questions and I'll be happy to assist.  With regard to the other items, I use ArcGIS Pro daily in my role as a Senior Instructor/Principal Technical Lead in Esri Training Services and for my classes I teach, have not run into issues.  But then again, I do not use the full suite of Pro's capabilities either.
Robert_LeClair
You can learn about all fixed BUGs for ArcGIS Pro 3.4.x here - ArcGIS Pro 3.4 Issues Addressed and all ArcGIS Pro 3.3.x bug fixes here - ArcGIS Pro 3.3 Issues Addressed
RTPL_AU
Hi @Robert_LeClair
Thank you for the contribution but I think you mis-read the post.
The question is what people still have issues with, not what's been fixed.
Robert_LeClair
Bud
Legendary Contributor
@RTPL_AU  Do you do any georeferencing?
I had some issues in 3.4.0 when georeferencing images. https://community.esri.com/t5/arcgis-pro-questions/what-filetype-is-the-most-stable-for/m-p/1572086/...
With that said, I can't say for sure if it was better in 3.3.x. And I have switched to using JPGs not TIFFs, which seems to have helped.
It might be worth your time to do a quick georeferencing test in 3.4.x to see how it goes.
Bud
Bud
Jake413
@Robert_LeClair, @RTPL_AU. I have a reoccurring issue in 3.4.2 with Map Series. Filtering dynamic text and tables by map series in Layout is not working.
This is mission-critical for me. But because of my permission levels, I can't report this bug myself.
RTPL_AU
@Jake413  if the behaviour you need is not there or behaves differently than you expect, lodge it as an Idea. If you can post here you should be able to post in Ideas.
Esri people will jump on it quickly if it is already implemented (but then they know its broken and you've done the best you can) or it is something they can add to the product roadmap.  Not all implemented Ideas are high kudos - sometimes it is a required feature but someone just forgot to add it in.
Bud
On the flip side, here is an issue that was a deal breaker for my I.T. department (in conjunction with other issues) when planning to upgrade From Pro 2.9.x to Pro 3.3.5 (Enterprise 11.3).
BUG-000171626 Multiple relates defined in a map cannot be published to ArcGIS Enterprise 11.3 due to the error "Ma...
I.T. has opted to upgrade to Pro 3.4.3 (Enterprise 11.3) instead, since the issue, and other issues, are fixed in Pro 3.4.
