North Arrow 56
3062
05-16-2019 12:23 PM
JustinHarwell
I am working on a project in ArcMap Pro, everyone normally works in ArcMap Desktop. We normally use the north arrow ESRI north 56 on are maps, however, ArcMap Pro does not have that as an option. Does anyone know where I might be able to import in ESRI North 56?
Yes, I know it really doesn't matter in the big picture, but it is something being requested and I try to meet expectations.
Any help would be greatly appreciated.
MatthewDriscoll
You can import them.
https://pro.arcgis.com/en/pro-app/help/projects/connect-to-a-style.htm
If you have ArcMap installed, you can import any of the styles included in that install to the ArcGIS Pro format.
MatthewDriscoll
JustinHarwell
Thank you! Do you know where I can find the style sheet for the esri north 56?
MatthewDriscoll
Not sure off the top of my head.  The path is in the link of my last comment.  The style file is probably called ESRI or ESRI North Arrows or something like that.  You can also save it to a new style file and just use that.
