Hi. My Python IDE is complaining that I cannot create a Network Dataset from Feature Classes that have a 64bit OID. Is that correct? The exact same code used to work before, so either the Network Dataset-capabilities of ArcGIS are regressing, which seems quite unlikely, or OpenStreetMaps has changed the OIDs in the regionthat I am trying to download.
Might there be a smar solution to work around this? I am intent on creating a Network for Germany, put together from the several States it consists of, so I would rather like to keep the original OIDs as far as it's possible.
Migrate Object ID To 64 Bit (Data Management)—ArcGIS Pro | Documentation
however
Create Network Dataset (Network Analyst)—ArcGIS Pro | Documentation
Source feature classes cannot have 64-bit object identifier (OID) fields.
It must be targeted for an upcoming version
Hi Dan, thank you for your reply. This is exactly what I found as well. I indeed hope that they will change this for the future.
Do you happen to have an idea how to circumvent this problem? As far as I can see it is not possible to reassign the OID field, so I'm a little lost here.
Hi Raven, I ran into the same problem. I solved it by using the Create Feature Class tool and setting the template as the network feature class I was trying to change and putting the OID type to 32 bit.
