Network Analyst MakeClosestFacilityAnalysisLayer Layer Name Parameter Broken
1147
11-05-2024 08:55 AM
ZacharyForsythe
Hey everyone,
I wanted to post this because it seems that I've run into a bug related to the arcpy behind the Network Analyst MakeClosestFacilityAnalysisLayer Function.
I'm currently going about the process of automating a project utilizing Network Analyst and I discovered that whenever attempting to preemptively give the generated Closest Facility Network Analyst Layer a name within arcpy (there's a parameter for this), the command instead outputs a Feature Dataset with a randomly generated name. I've tried fixing this probably around 15 times and can't identify any issues other than there being a bug in the command.
Thanks
DanPatterson
MVP Esteemed Contributor
It could be this
BUG-000133359 for ArcGIS Pro
... sort of retired...
ZacharyForsythe
That seems to be on the right track. I think, after reading the notes a couple times, that Bug pertains to issues with naming Sublayers. This particular problem is related to the creation of the "master" Closest Facility layer. Has anyone else experienced this?
