need lighter version of imagery basemap
4256
05-05-2023 04:33 PM
BarbaraDabney
ArcGIS Pro 3.1 - Beginner
I am looking for a lighter version of the Imagery or Hybrid Imagery basemap.  I am trying to make a readable layout and the closest scale I can get is 1:743. After that, it goes dark, I assume for privacy?  But we are doing a residential project to show to the residents and I need it lighter at 1:500 so they can see it better.  There is a draft attached.
Can anyone help me either find a lighter version or make the existing basemap lighter in my Project?
Thanks, Barbara
LindaWilliams1
Have you tried Google satellite imagery? I use it often because it can be zoomed in much closer. There's no control that I know of on the imagery dates, but I find it works well in many cases. I followed the instructions given here to put it in our portal (I saved it as a Favorite for easier access), then I open it in my current project and then copy the satellite layer into my active map. https://community.esri.com/t5/arcgis-pro-blog/add-google-maps-to-arcmap-and-pro/ba-p/1050830
LindaWilliams1
Have you tried looking at the same area in the ESRI World Imagery Wayback App? You might be able to find a date that has better lighting at that scale (https://livingatlas.arcgis.com/wayback/). You can then add that date's imagery to your map in Pro. This post describes one way to add the imagery in Pro:  https://www.esri.com/arcgis-blog/products/arcgis-living-atlas/imagery/wayback-server-connection-in-p... .
BarbaraDabney
Thank you. I did not know about this resource. However, it will not let me even get in that close on any of those. I'll keep looking.
Barbara
LindaWilliams1
BarbaraDabney
Thanks!
