Need advice on one map/multiple layouts in Pro 3.2
1822
07-26-2024 11:48 AM
TerriWaddell1
We are *finally* in the process of Migrating to ArcGIS Pro.  Currently we have numerous thematic maps that are pre-made and ready for staff to open/print for the public.  There is one MXD for each printout size.  (Example - fire district maps, one MXD for 8.5x11, one for 11x17, one for 24x36, one for 40x60).   We have a *ton* of these that I need to convert.
My understanding is that in Pro, you can do this in a single project with one map and many layouts that refer to that one map.  Awesome!
In Pro I imported one map and layout, made everything pretty, then imported the other MXD layouts to bring in the other sizes for that thematic map.  I edited those layouts so that all the elements fit properly.
After I added my third map size, Pro starting running so slow that I can barely do anything.  It acts as if, when I'm viewing one layout, it's also drawing the other layouts too even though they are not active.  If I dare to print a map, it takes at least 10 minutes to print.  One 8.5x11 map still hadn't printed by the time I came back from lunch.  I have rebooted many times and have cleared out the display cache.  I have all the layouts "Paused" except the one I am trying to print; that helped a tiny bit but is clunky and trying to explain that to inexperienced staff is not something I want to tackle if I can avoid it.
In on Pro 3.2 with patches installed.  The computer has 32 gb RAM. Do I need to make one map for each layout (which, um, defeats the purpose!)  Do I need to go back to having one map/layout in a project, like we did with ArcMap, instead of one Pro project with many layouts? Something else?
IWhat am I missing here?  Huge thanks!
IanLadd_Tourmaline
Hi Terri,
We've encountered the same issue as well. You've probably done all this, but having only 1 layout open at a time keeps it faster. We also keep the map group in the layout turned off as much as possible until going to print. We setup print presets that also try to minimize the time. Using the "print as image" button helps a good amount.
I find the layout section of Pro is extremely slow to use, so much so that we even design some of our elements in illustrator and load them as PNG's onto the map so we don't have to create simple graphics in PRO.
IanLadd_Tourmaline
Hi Terri,
TerriWaddell1
Those are great suggestions, thanks so much!
