name of vue or map and dynamic map.
683
07-16-2019 02:03 PM
MarcelSt-Germain
It's me or Pro 2.4 have trouble with structure of data between map, view and dynamic text path.
I change name in my map frame, layout.  Unfortunately, when using dynamic text, the names don't update so it's hard to follow in the CIMPATH.
By example, I have a Layout with a name "Section carte gche" with a MapFrame name "Carte1x_gch_ht".  Unfortunately, the dynamic by example for a table info is <dyn type="table" property="value" mapFrame="Section carte gche" mapMemberUri="CIMPATH=carte_gch/tuiles_cartes_pour_atlas.xml" isDynamic="true" field="no_carte" delimiter=" "/>
So the map frame is OK but why CIMPATH have others name change in the working process.
I haven't found a way to update it so the project has a clear structure.
Also, when inserting dynamic text, you see the good map frame name but, for the table name, its stay on the other one most of the time
